Hello everyone,
I’m thinking about adding a fiberglass tanning ledge (8’ x 8’ or so) to my existing fiberglass pool. I would have it raised so there would be a water fall to the main pool. My question goes out to those with this configuration with the following:
1) do you run treated water to the separate tanning ledge at all times the pump is running? I’m assuming so otherwise this would turn into a lagoon. Do you need to run it longer that 8-10 hours per day because it is so shallow?
2) if the answer above is yes, have you noticed a lot more evaporation or pH issues from the cascading water?
thank you in advance
