Back to my project. I got my pool filled last night and the kids got in the 64 degree water for a little bit. I think they're crazy. I was amazed by how much junk was in the pool due to all the falling spring blossoms, but this is my first year using a skimmer. They're fantastic! Cleared everything up in short order.
My next step was to try to get the heater connected. I think I mentioned it earlier, but my plan was to use a smaller pool pump to run a separate heater circuit since this heater is so restrictive. It would not be wise to put my main pump and filter inline with it because it would cut the flow down excessively. Anyhow, one of my little pumps does not generate enough pressure to trigger the heater to turn on, so I connected two of them in series. Now we're in business! With that setup, I was seeing a 59 degree rise in the water. That tells me I'm not moving as much water as before when I tested it with house water pressure. And as long as the efficiency is comparable to before (3 gpm raised 38 degrees) then I'm OK with this. I'll probably test my new gpm a little later to confirm the efficiency.
I also ran the heater for 20 minutes straight to test if it would shut off like it claims, and it did. I think my next step is to connect the thermostat and timer to it. My initial plan is to set the timer up to run for around 20 minutes at a time and then shut off for 10 minutes or so. To be clear, the way it works is the heater fires when it senses water pressure, so the thermostat will connect to the pumps, and the pumps will be plugged into the timer. As long as the thermostat is calling for heat, the timer will turn the pumps on for 20 minutes and off for 10 minutes in a cycle. I imagine I’ll end up tweaking this interval as I progress.
It rains a lot in the spring and I’ve got a deck to build for this pool, so I’ll be devoting much of my time to that project, but I’ll certainly report back about the progress and viability of this heater. I’ll also get some pictures up at some point.
