If the TA test turns immediately red, then that means that the pH is 4.5 or below. Not good. Immediate addition of pH Up / Soda Ash / Arm & Hammer Washing Soda / Sodium Carbonate is required.
For example, if I take 10,000 gallons of normal pool water to start with and I simply add 27 3" (8-ounce) Trichlor pucks/tabs to it and use up the chlorine that is produced (around 148 ppm FC or just a couple of months of typical chlorine usage), then I end up with a pH of 4.06 and a TA of -4.1 which would immediately show red on the TA test. I assumed this low pH would drive out most of the carbon dioxide from the pool. This amount of Trichlor also adds about 90 ppm CYA to the pool so in addition to pH adjustment, a partial drain/refill will likely be desireable as well.
To restore the pH to 7.5 when the TA test immediately shows red, it takes about 128 ounces weight (about 14 cups) of pH Up per 10,000 gallons and much of the TA will be restored as well (assuming most of the carbonates were lost to outgassing). It could take more, depending on how low the pH really is and to be safe one can add less and remeasure. After the pH is balanced, it may be necessary to add some Alkalinity Up / Baking Soda to increase the TA, but that's easy to determine by retesting.
Richard
