I have a Taylor test kit. Not sure what number any more as the part of the label where the test kit number is printed is faded and unreadable.
The TA test has three reagents. CR-007, 008 and 009. For every drop of 009 you ad to turn the mixture from green to pink is 10 ppm TA as CaCO3.
When I add the 6th drop the solution goes from green to dark greyish purple. When I add the 7th drop it turns a bright pink or pinky red. I interpret that result to mean my TA is somewhere between 60 and 70 ppm as CaCO3. Is that correct?
I was shooting for a final TA of 60 ppm. Is that result close enough to help maintain a stable pH?
