TA Suggestions
Jul 18, 2018
11
Leola, PA
Hello My Pool Peops,
New to using this forum so bare with me.
I am a bit confused about where my alkalinity should be. Seems like everywhere you go everyone has a different opinion of what range it should fall in between. Mine is currently stuck at 110 which I guess is on the high side but is it? It really has lingered around 100-110 for as long as I've had the pool (6 years). Pool Math App suggests it be between 50-90. But the TF-100 test kit suggests between 100-120. Both of which are supported by TFP. What do you go by here or is it a matter of preference? Looking forward to hearing what everyone thinks.
Thanks
Welcome to the forum!
TA of 50-90 ppm is based on keeping your CSI in a mid-range. Now, if CSI is not your issue, and with vinyl it rarely is, TA has little effect other than as a buffer for your pH. If your pH is stable, then there is little to worry about.
I suggest you read ABC's of Pool Water Chemistry.
So if my CSI is high which I believe it Is, where do you suggest bringing my TA levels down to? My CSI levels were very high last year due to hard water and using cal-hypo. I have resorted to using more liquid chlorine and bleach to limit the amount of calcium I add to the pool. I have not tested it yet this year to be honest.
To share your Poolmath data, go to the Gear icon, upper right. Scroll down to Sharing.
I get 0.36 with the app ----
I think the difference in app and webpage is how the salinity is handled on non-SWCG pools. Minor difference.
