Post a picture of your pool from the outdoors. There is no need for UV in an outdoor pool. With indoor pool, it will help you clear CC. With an indoor pool, I'd take clearing CC over a bit of FC loss.
Be interesting to see your setup. It may be that you get enough UV with the acrylic enclosure, that you don't need it. Or not.
I would experiment. When you smell "chlorine" is not chlorine, it is the chloramines. I would run it enough so that it eliminates the chorine smell. If you have to add a bit more chlorine, so be it!
