TA rising, not lowering
Karis
35
Moorhead, MN
Hello! I've tried to lower my total alkalinity for the past several days. The first time, I used Acid Magic and then aerated but it didn't do much and my numbers stayed the same. Figuring it had lost its efficacy, I used actual muriatic acid. It did lower the pH this time, so I aerated again, and now my TA climbed from 90 to 100! What am I doing wrong? Thanks!
Adding acid lowers TA. That is a chemical reality. It does not lower the TA by much at each addition.
Testing error, products adding TA, etc can contribute to what you are seeing.
