Moved from here.
I just recently had to do a partial drain and refill to reduce my CYA which had gone out of control from using chlorine tabs (learned that lesson the hard way and then started doing more serious reading here). I then got a real test kit (Taylor K-2006C) and tested my total alkalinity for the first time in a long time and realized my readings were awfully high there as well (220-230).
Over the past couple of days I've followed the process to reduce TA to 7.2 and then aerate back to 7.8 and repeat. I've done two cycles of this now and have achieved the following readings. Given my CSI is in the range Marty and others recommended above, am I ok with a TA reading of 165 or do I need to keep adding acid and aerating to bring it down further?
Thanks for the help!
My current readings are below:
Build Type: Vinyl
Volume: 30500 gallons
Latest Test Result Summary:
FC: 5.0 (21 hours ago)
CC: 0.0 (yesterday)
pH: 7.7 (an hour ago)
TA: 165 (an hour ago)
CH: 150 (2 days ago)
CYA: 50 (2 days ago)
TEMPERATURE: 84° (an hour ago)
CSI: 0.11 (an hour ago)
Build Type: Vinyl
CC: 0.0 (yesterday)
