TA Huge swing
Chief2505
49
West TN
CircuPool RJ-60 Plus
Ok so I finally converted to salt and I am a bit confused!
6-30 water test per me and my Taylor kit
FC 6.0
CC 6.0
PH 7.2
ALK 70 Added 12# baking soda
CYA 40
CH 70
Salt 200 (added 400# of salt)
7-1
Installed salt system
Salt 1700 added 280# of salt
7-2
FC 4.5
CC 4.5
PH 7.2 first test water straight from pool, 8.0 second test after water sitting on table for 20 minutes while I did all other tests, 8.0+ third test after going and getting a new water sample
ALK 80
CYA 40
CH 170
Salt 3000 according to Taylor, 3200 according to SWCG
What do I do? The chart in the Taylor kit does not match the chart in the owners manual of the SWCG and neither of them match TFP recommendations as to what each level should be.
Follow TFP recommendations:
Leave your TA alone. Lower TA works better with a SWG.
How did your CH increase?
Reactions: pjt
You indicate you added 12 lbs of baking soda. That should raise TA by 25 ppm in your pool.
I am sorry, I typed that incorrectly. I said I am really curious why the TA changed so much.
I meant why did the PH change so much from test # 1 to test # 2 this morning.
And I know what the math says about the baking soda and TA but the Taylor TA test is one I am fairly certain I am reading correctly.
It's unlikely that the pH changed that significantly in that short amount of time. It's possibly a testing error or some type of interference from a contaminated comparator, vile, or sample bottle.
Reactions: proavia
I am not sure what happened but test results this morning.
FC/CC 4.0 4.0
PH 7.8-8.0
ALK 80
CYA 40
Ch 170
Salt ??? I quit adding drops at 5,000 PPM, 25 test drops! My SWCG says salinity is bouncing between 3000 and 3200. I only added 680 pounds of salt, which according to pool math should put me around 2300 + the 200 I started with. According to Circupool manual that amount of salt added should leave a level around 3,000. I went back to the pool this morning and got a second water sample and redid the Taylor test. This time I quit adding drops at 20, the test water turned white but never changed to salmon brown/pink.
The SWCG is running at 75%.
What am I missing? Could my new test kit be bad? I even double checked the amount of water in the pool. The builder says 35,000, the previous owner says 32,000, my calculations say 34,000. How can my salinity be so far off from the SWCG? The pump has been running non stop for 3 days!
I cannot believe how fast my PH jumped and how far off my salt level appears to be.
That is exactly what I did! Stopped reading at the 25ml!! Followed ALL of the directions this morning and I have the following
FC/CC 4.0-4.0
PH 8.0+
ALK 80
CYA 40
Salt 3200
CH 170
Got to get that PH down today!
