I am in the process of switching my pool over to salt water. I am working on getting all of my levels to where they need to be before we start up the generator. My salt level is at 3400 which is right where it needs to be as per my generators instructions. My free chlorine level went way down over these past couple of days and I think I may need to go ahead and shock before we make the switch over. I plan on using liquid chlorine to shock with. My question is do I shock per the standards of a saltwater generated pool at a CYA of 70 (thats where i am w/ CYA)? My other question is why on a freshwater pool does the free chlorine go up as the CYA goes up but when I look at the salt water CYA chart the free chlorine level is down for a higher CYA? Example freshwater pool CYA of 50 calls for free chlorine levels to be between 6 to 8… Salt water generated pools with the CYA of 70 to 80 call for 3 to 6 ppm a free chlorine? Just curious.
