I will be installing a CurcuPool RJ30 Plus sometime in the next 2 weeks. I will also be installing a new Hayward Sp3202VSP Tristar pump at the same time. My questions are about how to connect everything. I currently have a Hayward SuperPump running on a timer. The RJ instructions say to wire it into the pump timer. The new pump will not use the timer, as all functions are built into the control module. I don't want to rely on the flow switch to turn the SWG off. Is it possible to just keep the timer and wire it into the RJ controller but not the pump? If I wire the new pump directly into the breaker connections and if I keep the input line into the timer but remove the load out line, that would normally go to the pump and wire the RJ controller into this line. I don't see how this wouldn't work and the timer would then turn the RJ off but the pump would be independent of the timer. I am not an electrician, so I was hoping to get some help on this from some of you guru's.
