- Jun 14, 2021
- 14
- Vinyl
- CircuPool RJ-45 Plus
Moved from HERE
Did you end up converting? I'm trying to find a SWG that will be easy to switch out the current Perma Salt system and not have to mess with a lot of replumbing. I have a 30" above ground pool. Did you end up draining the water?Hello, I am somewhat considering converting my 24' x 54" above ground Perma salt pool to a SWG. One concern I have is the residual copper currently in the water. Would that be a problem for the SWG system? Another is, it will void my pool warrantee because of the possibility of rusting the metal pool structure. Has that turned out to really be an issue. Do you add anodes? Thanks!
