I have had a rash for the last six months that the dr can not figure out. Not bacterial not fungal. It gets way worse after using the hot tub (could just be the heat inflaming it, but) I think I may have a problem with the chemicals I am using. I used the chlorine system on my pool and never had a problem so I think we will switch to that for the hot tub and see if this goes away.
So I will use awesome, do I leave the filters in the hot tub while using it? Should I buy new filters?
How do I get ALL the bromine out, if I drain all I can and use a shop vac to get the water on the bottom of the tub out is that good enough? Should I partially refill and drain again to minimize the amount of bromine water that was left in the pipes?
