SwimPure Plus randomly changes cell size
Jun 3, 2013
12
Hello, recently my SwimPure Plus has randomly changed the salt cell size on its own. Has happened three times in the past 4 weeks. I've got a t-15 and it's changed that to smaller cell sizes. That led to it registering the salt level as too high and then ceasing chlorine generation as a result. Each time it's happened, I changed it back to t-15 and it's run normally again. The program code is AL-0, software version is 'r 1.55', and it's about 8 years old.
Anyone else run into something similar with their system? Thanks!
Check out the Wiki article on Aquarite SWCG's.
Check to make sure that the T-Cell type is correct in diagnostics. When the pins don't make good contact, the settings randomly change and the screen can get jumbled. If the T-cell type gets on the wrong setting, the salt reading will be wrong.
Reactions: C0d3Sp4c3
