Considering having a Swimex pool installed in the home we are planning. It would be indoors. Have a couple of questions:
- On the Swimex website FAQ, they don't recommend salt chlorination. To quote: "We recommend against the use of salt sanitizers. If not balanced properly it will lead to excessive chloramine being produced. This can cause fluctuation in pH and will make your water – and possibly air – corrosive, leading to rust on metal surfaces." While I know that the salt chlorine generator can cause pH rise, are chloramines any more of a problem than they would be with other forms of chlorine?
- Since the pool will be indoors, some supplemental oxidation will be necessary as I understand it. Both UV and ozonators are offered as options. Which would be the better choice?
- Swimex also recommends draining, cleaning, and waxing the surface (it is fiberglass) annually. Is this really necessary if the water is properly maintained?
