After doing some research and trying out a unit, we've decided to include a Swimex pool in our new home plans. The pool will be in indoor conditioned space, covered when not in use, and holds about 2600 gallons. Surface area is approximately 8x18 feet. Pool will be used pretty much every day year round for an hour or so. Not much if any debris should find its way into the pool, which will be in a room dedicated to fitness. The pool equipment will in all probability be installed below water level, protected from the elements. Here is a list of the equipment that comes standard with the unit:
- Pump - Optiflow 1HP
- Filter - Clean and Clear 75 sq. ft cartridge filter
- Heater - Coates Model 12406ST 5.5 kW Electric Spa Heater
