I tend to agree with Jason on this one - the phosphate remover likely knocked out a necessary nutrient source for the algae and allowed your SWG to recover it's footing. An IC-20 in a pool your size is only going to produce 7ppm per day FC at 100% output. If there is any algae in the water that is reproducing, then it could easily overwhelm a cell of that size. Algae is only visible (cloudy or tinge of green) when it has reached fairly high levels and so even a "clear" pool can have a significant load of algae in it. In retrospect, your cell and testing were actually telling you there was an algae problem even though the water clarity was not.
Now it's not a bad thing that you reduced your phosphates down to zero (they won't stay there), it's just that your situation could have been fixed by merely elevating the FC levels with liquid chlorine for a period of 24-48 hours and possibly not even all the way to SLAM levels. A few extra bottles of bleach/liquid chlorine would likely have been cheaper than the bottle of PhosFREE.
Anyway, it sounds like the SWG is running normally again and you've been armed with greater knowledge for the next time this issue shows up....oh, and in case you're itching to remove phosphates again, don't use PhosFREE, it's like the "light beer" of phosphate removers. SeaKlear Phosphate Remover is much more concentrated and does not contain any extra clarifiers in it. If you need a clarifier, you can add one separately. Orenda PR-10000 is also a very high quality, concentrated phosphate removal product that doesn't use extra clarifiers.
