I am planning to purchase the RJ45 before the $1 upgrade sale ends on 8/24. I have a couple of questions that I haven't quite wrapped my brain around yet and it's holding me up from pulling the trigger.
1) i have a vertical run that I think will work for the cell. I'll post a few pics. Is there any reason this is not a good location?
2) Currently my pump timer is not working. trying to diagnose the issue - clock seems to move but get stuck at the on and off switches. In other words the timer stops at which ever switch is next until I move it past that switch and then the timer stops again at the next switch. Any suggestions? I'm guessing I just need to replace the mechanism and it seems the model has been discontinued. I'm open to suggestions for replacement or repair.
3) wiring: I understand the SWG needs to turn on ideally 15 min after and shut off 15 min before the pump. If my timer is repairable, and it is acceptable for the SWG and pump to turn on/off together instead of the 15 min lag, how would I wire the swg to the timer? If the timer is not repairable or it just makes more sense, what timer would be cost effective and work best in my situation? See attached pictures. There is a second breaker and switch in my system for a polaris which we don't have/plan to buy. Would it make more sence to have a second time for the swg set up from the polaris breaker? Or is that an added expense that is unnecessary?
Thanks so much for any input! I'm a diyer for many things but a newbie to DIYing pool stuff. After an algae bloom and doing a SLAM last month to fix it, I'm sold on TFP! You all are a help and resource.
