SWG that is compatible with pool timer?
snedecor
5
Angleton, TX
I have an above ground pool, with Intex pump, sand filter, and installed skimmer. The pump is run by a pool timer, 6 hr. on, 6 hr. off
I had an old Intex chlorine generator, and it came on and off with the pool timer. After it died, I got another Intex QS1200 chlorine generator, but it would not come on and off with the pool timer.
I don't want to run a continuous power supply to the SWG, because then the pool pump and the SWG will get out of phase.
Is there a SWG that will come on when power is given by a pool timer?
Thanks!
The Intex SWCG are the only ones that have their odd internal timer set up.
As Mark said, look at the Circupool SWCG's for your set up. Tie the power to your timer in sync with the pump.
Reactions: markayash
