- Jul 10, 2020
- 155
- Plaster
- Pentair Intellichlor IC-40
Rather than hijack the "SWG settings and regulating with varying pump speeds" thread I'll post my questions here....
From that thread:
One misconception I've had that you cleared up is that FC output of a SWG is not based on flow/pump RPMs (assuming it is running fast enough to generate any FC), but rather on the % of capacity set for the SWG. That makes sense to me now.
What I still have a hard time wrapping my head around is why CYA is targeted so high for a SWG pool, especially where the "ideal" target is so close to the point at which you would need to drain and refill should a SLAM be required.
This is our first in-ground pool and our first season with it so it's a whole new learning experience. We spent more than we had hoped to get the pool in the ground and running so keeping operating costs to a minimum is important. Just as important, however, is operating it at levels that will help to keep the equipment and the plaster in optimal condition long term. Understanding why the various "ideal" levels are what they are will help us to maintain our discipline and to identify where it might be appropriate for us to make minor adjustments to those targets.
From that thread:
The whole point of CYA is to reduce the amount of FC consumed by the sun. Once your FC is increased, it does not take more chlorine to keep it there.
@Jimrahbe - A side note on that thread might be helpful to folks like me who want to better understand SWG output and the recommended/ideal targets for both CYA and FC. I know am much better at following instructions when I know the "why" of things and I'm sure others do, too.The higher the CYA the more of the FC is buffered and the less you feel it.
A pool without CYA is much harsher feeling than a pool with CYA.
I run my pool at about 7 ppm of FC. You cannot tell there is any chlorine in the water, no smell, no feel, nothing.
- Is the point of CYA @ 70-80 to extend the life of the SWG by virtue of being able to run it at a lower % of capacity once you hit the target FC?
- If the pool is covered (solar cover) for a large part of the day when the pool is not in use does that reduce the need for maintaining the higher CYA level?
- Does the "buffer" from the CYA reduce the risk of dropping below the "minimum" FC target (and thus reduce the risk of an algae outbreak)?
