7am FC - 8 added half gallon (should have boosted to10.5)
8:15 pool guy test said FC - 9 (pool was open to sun for about an hour)
9:30/10am backwashed, added a 1/2 to an inch of new water, added a gallon (gallon +5, sun loss and new water maybe even overall)
11:30 -FC 13. (seems right, maybe high in retrospect, I think I tested right)
3:30 - FC back to 8.5 (Dang) - added a half gallon (should boost to 11ppm)
Just now 8.45 pm
FC 9.5 (Dang) - added a gallon (should boost to 14.5ppm). unplugged SWG. Going to test at 10ish for an OCLT.
Expecting poor results and perhaps a morning drink.
Checked under the cover as best I could. Could see about 15 feet and no signs of issues. Skimmer clean. didn't dive in to check the lights or the drain.
Current guesses:
1. DE filter is coated in awfulness. I'm slightly afraid I'll screw up the filter trying to open and clean it.
2. CYA is really low, somehow, and I need to add yet another 2 lbs.
3. Phosphates are insane and causing some ugliness (yes I know)
4. The enormous amounts of sequestrant agents I put in are eating all of the FC while slowly (due to the low 7.2 pH) degrading, and I'll have an awful brown pool once it finishes the process (please God no).
5. Bacteria (if my morning loss is bad I'm going to LPS to test for ammonia to (hopefully) rule that out.
Just for fun, either micro bubbles or DE is coming out of the return jets in the stairs. Both of which are leak points that I had fixed via epoxy, with the leak company said could start to leak any time - or, the DE setup is leaking DE into the pool. Not sure which I want to happen least.
