I understood from most things that I’ve read it was better to have the pump come on in advance of the SWG. But you’re saying this set up will be good to go?
I have those but haven't installed yet. No reason to. Nothing is using itThe only thing I see as missing are the little dammits that tell the timer to switch "on" and "off". I don't know the official name of 'em but Skippy says he calls them dammits cause that's what you say when one is missing. (He said the name is the same as the the little pin back on his military uniform pins and medals). Do you know what I'm talking about? Ours actually are marked "on" and "off".
Maddie![]()
Yes.. that is how I have mine setup... the little "dammits" (I like that term) allow the timer to turn it on and off for you on a scheduleI understood from most things that I’ve read it was better to have the pump come on in advance of the SWG. But you’re saying this set up will be good to go?
The on /off clamps on the timer are called trippers. Secondly I'm not sure you need that many run time hours in the pool off season. Find your target and figure out the minimum you want to run the pump and adjust the % till you hit the FC target your aiming for.Here goes nothing. It’s all hard wired to the timer. Pool pump & SWG on. More cya being dissolved in the pool.
Timer is set for 5 hours during the day & 5 at night for the “pool closed” months we have.
Now all I have to do is test & find the sweet spot on FC using the SWG and maintain PH & TA?
Just confirmed my manual does say "will not produce below 65°. Not sure how winter mode works. Call circupool for that explanation.Really?! That seems to me like very minimal already although I’ve always had it running 24/7 prior to now. It’s strange to look out & not see the water circulating.
I kinda like the nick name above but Ik it’s good to know the true name. Thank you.
Also I read if the water gets below 65 degrees I should not use the SWG. Does anyone have any idea why? Do I turn off the unit or will it just not kick on? The instruction book didn’t say.
Do I just decide a minimum # of hours per day to run the pump/SWG? Or will I find this information on the TFP site somewhere?
@Flying Tivo - you only run your pool 3hours a day?! I guess I’ll have to drastically adjust my thoughts on “stagnant” water. Ik - that’s not the same as a pool but that’s where my brain goes to. And you’ve had no issues with algae? I’m learning in an all new ball park now with the SWG. Just as I’d gotten a handle on the non SWG way.
