Hi All!
New pool owner, construction complete 27 May 2021. 16k gallon SW Pool.
I did a search but cannot locate my issues.
1. Our system consists of Pentair IC40 SWG, Pentair Superflo VST Pump, and Pentair Easytouch Control System for Pool and Spa 5K42 (no spa with our build).
2. Our pool pump runs 24 hours a day. 8 high speed, 8 mid, and 8 low.
3. The PB states the pump cannot be controlled via the control system as this model lacks that feature without installing additional relays to control the pump. I cannot determine if this is accurate. Right now, I have to control the pump via the control panel on the pump. THoughts?
4. Our SWG turns off every 12 hours or so. Cannot figure out why. It is wired to the filter pump relay, but without the pump controlled via the control panel, I am not sure this is the correct wiring.
5. I can control the "on and off" function of the SWG via the Screenlogic app and desktop client, however, that happens via the "Pool" section, and tapping the Pool icon at the top. The Intellichlor section reads correctly.
6. The "Spa" section on the Screenlogic app is able to be "hidden" via the config menus of the screen logic desktop client, and it does disappear for a short time (1 hour or so) then re-appears.
7. All other areas seem to work correctly. No heater installed, Globrite LEDs, deck jets with automated actuator valve (although not able to adjust pump, see above), extra power/lighting outlets controlled via the app.
Our PB has been great so far and responsive and helpful, however, this is the area that they seem to be lacking in.
Any help would be greatly appreciated!
