- Apr 3, 2015
- 642
- Vinyl
- CircuPool RJ-45 Plus
Hello. I am looing to add a SWCG next spring when I open the pool. I don't have automation and don't want it (actually don't want to spend the money...I'd love it). From what I understand without the automation I can only increase in 10% or 20% increments (don't remember which one). Is it worth it to get the SWCG still? I don't mind if I need to run my pump a little longer to meet the need if I had to use a lower setting. I run 8 hours a day as it is so I'm assuming I'd be ok with that run time and just need to find the % that keeps the pool in line. I have all Jandy equipment but without automation is there any reason to stick with Jandy? I was leaning towards another based on things I've read here. Thanks a lot. Counting down the days until spring arrives
