Trying to figure out what combination of equipment would be best and at the same time without spending a small fortune on it. I was all set a few weeks ago to spend some cash doing this, but emergency water heater install derailed that plan and some of the cash flow.
Currently, I have an IC15 that's 5-6 years old, not making chlorine since last fall. Cell still shows 40% life remaining, but I'm pretty sure the flowswitch is bad. Either way, if I get anything other that an IC15 replacement, I would also need the power center as well. Considering the new Ichlor 30...dealer is offering it at $799 with the power center. I guess an IC 40 would be a few hundred bucks extra.
Previously, I was looking at integrating an EasyTouch since I need a power center anyway, but it was pointed out that my SuperFlo VS won't play well with it. Also, I didn't know (before finding you wonderful folks) that the SWCG be set up to completely power off when the pump does, so I'll need to do that as well with the new install. Additionally, looking to switch from sand to cartridge filter.
Suggestions welcome on what combination of equipment I should be looking for.
