- Sep 14, 2023
- 107
- Plaster
- Jandy Aquapure 1400
I’ve read quite a bit in the forum about this topic but what Im seeing doesn’t seem to align . I’ll assume I’m looking at this incorrectly and look forward to getting smarter on the subject. Also, full disclosure, my pool experience began last October so I am definitely not an expert.
For the last couple of months, since the pool has been below 54 F, I’ve been maintaining FC levels with liquids chlorine. My TA has been 70 and I’ll let PH go to 8.0 before adjusting. It would seem to hover in the high 7’s for over a week before needing any MA to bring it back to 7.6.
Now that my pool temp is in the high 50’s and lower 60’s, I’ve raised my salt levels to 3200 ppm and put the SWCG to work. Only needing to run it between 10% and 20% to maintain proper FC levels. CYA is at 50 ppm for now. Now that the SWCG is on the job my PH rises much quicker from 7.8 one day to 8+ the next. Yes I have a spa spillover and tanning ledge bubblers that run for 5 mins per day to circulate the chlorine. That has been a constant thought, nothing new. The only thing that has changed recently is the use of the SWCG. Am I to believe that the SWCG is not responsible for my rapidly rising PH?
