Hello everyone.
After reading tons on this site, and considering the fact that I live in a desert, I'd like to install a SWCG. But I couldn't find a conversion howto, so does that mean the installation manuals tell everything I need to know?
I've been using 10% sodium hypochlorite the past couple weeks, and a lot of it (about a gallon every other day) once I realized the tablets I was using in a floaterwere evil had sent my CYA off the charts. (Pool store test.) So my sodium level is likely already elevated. I have a new TF-100 on the way along with some salt test strips to find out for sure. The pool store also said my CH is getting up there, 380ppm as of last week.
I plan to self-install. I've worked with PVC and electrical many times before so no fear there. My plan is:
Thanks so much for your help!
- Test replacement water from automatic filler with TF-100 (for CH and salt especially.)
- Wait until the intense sun cooks CYA down to 80. (Should I maintain this level with a SWCG given the climate? 100+ degree days for 4 months of the year, pool open year-round.)
- Check CH & salt levels. Add salt/replace water if needed. (I have no waste piping so what's the best way to drain water? Via the high-flow PR valve on the filter into a bucket hundreds of times?)
- Install SWCG inline after heater, wired to mechanical pump timer.
