I didn't want to hijack @jeffpat 's thread so starting my own. I'm considering either the Circupool Core-35 or the Core-55. My pool is 17,500 gallons. Would the 35 be big enough or should I just go as big as possible with the 55?
Also, the spot I was going to place it doesn't seem to have enough straight pipe. The manual says you need 11". I have a section between elbows that is 9.5 inches long. The template has cut marks 7.5 inches apart which would leave 1" on each side in my situation and those unions look to be much bigger than 1". Soooo, I'll have to cut out that whole first section and make a new piece with a longer run. Thoughts and comments?
