Guinness418 said:
How's the color? At the very beginning of my swamp conversion I brought pool up to mustard algae level (just in case) and let it come down to shock level and after a few days found no more CC even as the color was still foggy green. Just a thought. Also I'm not *Sure* that it helped but the other day when I posted that the color didn't seem to be getting any better in my pool I added the DE to the sand filter and 4 days days later my water is clearing up and I can see the bottom of the shallow end. Just some thoughts as I'm a newer pool owner that went through similar stuff. The other more experianced people can tell you if I'm way off track or not.
It seems darker now that I have been hovering closer to shock level. Early on (last week) I was always a few points above shock. The color seems to be a large factor of the sun as well, the brighter the sun, the better the color, so it is hard to tell if the color is improving from day to day.
Where do you get DE? I know a friend who has some DE they ordered online for something, that maybe I can acquire a few cupfuls from. Also the filter has been in play just over 24 hours, so I hope to make major strides now that it is functioning. The steps are pretty clear in my pool and if I stood perfectly still and with the sun at my back I could make out the bottom of the shallow end of my pool
It does not appear to be white as I had anticipated. I found my boat shoes and have been considering entering the swamp this weekend to get a good brush of the shallow end at least. I did find two dead animals when I originally was netting the bottom, so there is likely to be others around in there somewhere, which makes me a little nervous in entering "the unknown".
How is your temp? 86 F seems high for this area, but the water does feel warm for whatever reason.
Appeciate your inputs, I browsed some of the conversion threads last nght, and it is hard to beleive some of the transformations. The beginning pictures look familiar to mine in some cases, It is just hard to imagine my pool ever looking like the "after" photos. Looking forward to it though.
It seemed a common theme has been brushing and vacuuming the pool is very helpful in getting there faster, and is something I need to concentrate on now that I have the pool equipment running. I did try vacuuming earlier, but the pump did not seem to be able to create any suction in the vacuum hose. :|
