- Jun 14, 2012
- 2,671
- Vinyl
- CircuPool Edge-40
Thank you! I couldn’t find it. That’s magical sounding indeed. Does the treatment last a while?
3 years haven't had to do it again....Not sure if it will fix your as they are more extreme, but where I would start..Thank you! I couldn’t find it. That’s magical sounding indeed. Does the treatment last a while?
Agreed. Slightly cloudy. Cya is now measuring 30.Almost there! I can't quite tell what the screws are on the main drain yet (philips vs. flat-head).![]()
Planning to. Need to order it.Use this stuff on the steps and will make them white again...Great Job!
STEP STUFF KITS | Jacks Magic
jacksmagic.com
As I’ve said before, that ladder isn’t able to be removed. I’ve had professionals try for hours on multiple occasions. It’s stuck despite all efforts. The pool has been in use many years with this same issue. It will clear up to be Crystal clear eventually. That approach likely would speed it up but it’s not an option open to me.Remove that ladder and scrub inside the tubes with a brush, and 10:1 water:chlorine to kill algae in those tubes.
Aim for 70- you may need to go to eventually 80 in the dog days of summer. Easier to do smaller increments anywayPassed OCLT - now letting the FC drop a bit and tune in pump run time vs swg output. Need to fine tune ph and ta and raise cya higher. It should be about 45-50 at this point. I want it around 75-80 I think.
Frequent backwashing and minor leaks mean levels drift down - I’m always nervous starting low. Maybe 75?Aim for 70- you may need to go to eventually 80 in the dog days of summer. Easier to do smaller increments anyway
How often are you backwashing? I only backwash when pressure rises 25% over clean pressure which is maybe a handful of times during my 7 month season. I have moderate debris that gets in my pool. My pool is twice the size of yours & the filter is just 50# larger. Sand actually filters better when it’s a little bit dirty.Frequent backwashing and minor leaks mean levels drift down - I’m always nervous starting low. Maybe 75?
I backwash at 20% but I can try 25% this year. In truth it isn’t super frequent except during slam. What’s more impactful is the fact I think I may have a small leak but I’m not sure yet. I’ll watch things as the season progresses.How often are you backwashing? I only backwash when pressure rises 25% over clean pressure which is maybe a handful of times during my 7 month season. I have moderate debris that gets in my pool. My pool is twice the size of yours & the filter is just 50# larger. Sand actually filters better when it’s a little bit dirty.
