- Jun 14, 2012
- 2,671
- Vinyl
- CircuPool Edge-40
No water exchange. Some water has been added after a lot of backwashing.Wow. That is quite the soup. Something is cooking in there. Did you ever do a partial water exchange?
As for the foam… my in laws have some cognitive issues (not a joke) and they try to “help”. I had asked them to start stockpiling bleach. They didn’t, they put some in. They often in the past would get the wrong bleach (scented, outdoor, etc) and put it in. This is one reason we changed to an SWG last year. I think at least some of this is due to that - but I’m also using CalHypo 65% as my CL source. Liquid is crazy expensive here (almost $10 for 121 Oz of 7.5%) and I had a very low CH level so I felt it was an option. I found 25lbs for $100 so that was cheaper than bleach as my initial starting CL. Planning to switch to bleach as the CH gets over 200ppm. It’s possible there’s something in the CalHypo causing foaming - this is granular but labeled shock. Perhaps in the 35% they’ve added flocculants and it’s foaming? I’m still pulling leaves from the bottom, so the breakdown of organic material is ongoing. CC is rather high at 2.5-3 ppm.
3.5 lbs of CYA added (target 30ppm). I haven’t bothered to re-measure the CYA yet due to the typical lag in it showing up on the test. However I’ve seen an improvement in the holding of Chlorine levels. I’ve added about 1” of water since the CYA was out in the pool and I haven’t calculated the drop in cya that would cause. Given the overall size of the pool I’m assuming it’s less than 1ppm drop and treating it as 30ppm until I can reliably test cya (my recall is that it can take up to a week to show up on the test).I noticed above your CYA was listed a zero or not tested. Did you ever add any? I wouldn't want to have unbuffered chlorine on that liner for a long time is all.
I wish I had a picture from the pre-starting day. The water was nearly BLACK it was so green. The water that came out of the leaf net was dark green in streams. I could take a sample cup and see dark green water in it. That water is now barely tinted as is more typical. Bear in mind as well that I don’t live there so I have to work in less than idea ways. I have spent most of this weekend over there trying to make progress - which I am. Today is the start of day 4. I’m not discouraged, this is progress.
