- Jul 21, 2020
- 159
- Fiberglass
- Jandy Truclear / Ei
Heard what sounded like short cycling back at pool equipment pad. Found heater having a "sw open" error. Did some googling. I've cleaned sand filter which I knew wasn't an issue because I had just done it. Both skimmers seem to be pulling water in just fine so I'm just assuming the switch is stuck open. Is there anything else I can check and is it ok to run heater while it's doing this?
