Good evening everyone - I am in the process of hopefully adding a new pool in the SW Florida area (which means a pool cage too!). I've gotten quotes from 4 builders in the area and I've included what I believe to be my best option (not the cheapest, not the most expensive, family-owned builder, good reviews/recommendations). I've done a lot of reading on here the last few weeks so I've already changed a few things from the original quote (switch to VS pump from two speed pump, etc.). I was just hoping to get anyone's opinions on the quote below, see if there are any glaring omissions or any obvious changes that should be considered. This will be my first pool, so I don't want to make too many rookie mistakes, especially if I can catch them from the very beginning. We have voted against the deck jets, even though they are included in the sketch.
Thanks in advance to anyone that takes a minute to have a look.
Scope of Work:
Construct new Concrete Swimming Pool, Paver Deck and Screen Enclosure. Please see attached sketch.
Includes:
Design, engineering and permits
Standard electric hook up, 4’ X 8’ Concrete Filter Pad and Alarms
14’ X 28’ Concrete Swimming Pool with Steps & Deep End Bench
Pentair 1.5 HP VS Variable Speed Pump
Pentair 150 Sq Ft Cartridge Filter and Rainbow 320 Chlorine Feeder
(2) Pentair Color Changing LED Lights with Transformer
Hayward Surface Skimmer with Self Adjusting Weir
(5) Pressure return lines, overflow line and 2” dedicated vacuum line
Choice of Waterline Tile $6 Allowance- Includes many Glass Tiles!!
Choice of Color Flagstone Paver Coping
Florida Stucco Silver Pearl Interior Finish
Maintenance kit, Chemical start-up and 30 Day Service
Includes: Dirt and Sod removal
Exclusions: Landscaping, Shutters, Fencing or sprinkler system work. We will cap off any visible sprinkler pipes. We will grade the yard back.
Options:
Pool Deck
800 Sq Ft Flagstone Concrete Paver Deck, Screen Footer, (2) Door Pads and Deck O Drain-Choice of color and pattern to match Pool coping. Includes Thin Pavers on Existing Lanai.
Screen Enclosure
34’ X 41’ 3” X 24’ Aluminum Screen Enclosure with 9’ Mansard Construction, 7” Super Gutter, (2) Doors and Downspouts and hardware. Made with Fifer American screen material and Cadmium steel screws dipped in porcelain.
White or Bronze
Pool, Paver Deck and Screen Enclosure Total $50,150
For 8’ X 8’ Sun Shelf with (2) Bubbler Fountains, add $1,000
For Gulfstream HE-125 Heat Pump- 125,000 BTU, add $3,450
For PureChlor 20 Salt Chlorine Generator, add $1,100
For (2) Adjustable Deck Jets with valves, add $900
Construction Specifications:
2020 Florida Building Code
Standard excavation with #57 Stone base with Well Point
Minimum #3 Rebar @ 12” CEW Structure
4000 PSI Gunite or Shotcrete Structure
Scope of Work:
Includes:
Options:
Pool Deck
Screen Enclosure
White or Bronze
