Good Morning, since last week I noticed yellowish staining on one of the steps and thought it was pollen, even though I have no pollen floating on the surface. I brushed it away and when brushing I could see the cloudy residue in the water. The yellowing did not go away completely even after brushing and scrubbing. After brining my FC and PH in line the yellowing faded away by the next day. I usually add a half gallon of LC daily and I do realize this is not the way to handle maintenance without checking my levels. Yesterday, on the same step the yellowish staining reappeared but now it also appeared on the opposite side of the pool on the other step. I don't see any yellowing on the pool walls. I also noticed the formation of black algae along the tile line in several areas. I've dealt with black algae before and was able to get rid of it. I suspect the yellowish staining is mustard algae since we don't have any more pollen in my area. The area of the staining doesn't go away completely.
In a panic I poured in three gallons of LC and kept the pump running all night. I realize now that I should have checked all my levels before adding so much LC, but again I didn't give it a second thought. Plus my testing supplies are over a year old and the four little containers of my FAS-DPD turned black so I assume it's no good to use.
Two questions:
1) To any members in the Northwest Houston area, near Spring, TX that may know of a company or person who maintains pools following the TFP recommendations, please let me know. I want to turn the maintenance over to someone since I continue to fail with the maintenance due to my busy work schedule, travel and not having anyone else at home to help.
2) The pool water looks clean and clear but is it safe to use the pool if in fact there is black and mustard algae present. I ask because I have family visiting this weekend with kids who will want to jump in, but I will close the pool if it's not safe.
I appreciate the help and advice. These are photos from this morning
Two questions:
