Sundance jailbreak
Status
Not open for further replies.
Pound Salt
5
Plymouth, CT
Hi all. Does anyone know how to jailbreak a new Sundance spa to get some extra degrees over 104? My spa provider swears they have no idea what I am talking about. Good troopers. But at the slight altitude we are at 104 is just not quite enough. Thx!
JoyfulNoise
Platinum Supporter
May 23, 2015
17,458
Pentair Intellichlor IC-40
Operating a hot tub above 104F is not recommended as it presents a health hazard. When the human body temperature rises above 104F, hyperthermia is a real danger. Hot tub manufacturers build a high temperature limit switch into their heater hardware that will turn off the heater in the event the water temp goes above 104F. There are also software controls that limit the temperature set point. This is all done for liability issues. You would not be able to circumvent the software heater controls easily and you would have to willingly bypass the high temp switch to keep the heater running beyond 104F. None of that is advised as it could be potentially harmful to your health and the health and safety of those that use the tub.
If it's cold outside, perhaps get some propane powered radiant heaters to put near the tub to help offset the chilly air....
RDspaguy
In The Industry
Mar 21, 2020
1,011
Cabool, Mo
You used to be able to program that board with a jumper pin to operater up to 108f. We would make you sign a waiver before doing it. To my knowledge that feature was eliminated about a decade ago. I will dig up my old sundance manual and see which one it was if I can find it.
JamesW
21,603
No advice should be given about how to set the temperature above 104 degrees.
Do not set the temperature above 104 degrees. It is not safe.
Status
