I have a 8' x 15' sun shelf that maintains around 6-8" of water. There is a significant difference of temperature of the water (it runs about 5-8 degrees hotter). I have one return on the shelf that moves water, but when I run my pump at 1000 rpm (which is approx. 18 hours a day) - I am not sure there is enough water movement. So my question is if I run my 2 bubblers also - will that help water movement? At 1000 rpm the bubblers just barely create a ripple in the water. Am I correct in saying that the low volume will NOT raise the pH but move water creating temperature decrease?
Besides, the little ripple it creates makes my Pebble Tec Clearwater look sooooo much better!!!!!!
Open for input! Thanks
