- Feb 3, 2019
- 6
- Plaster
- Hayward Aqua Rite (T-15)
My 1½ HP single speed pump died and I replaced it with a 1½ HP Pentair SuperFlo VS. I have three timer options available. Currently I set it to run at 3000 rpm for two hours and at 1450 RPM for six hours. I've not set the third timer.
My Pool: 10k gal, plaster, 1½ Hp Pentair 342001 SuperFlo VS pump, Hayward CX 1300RE cartridge filter, Hayward AquaRite SWG w/T-Cell 9, Gulfstream HIE 110-R-A heatpump, Superscreen cage, Pentair Rebel pool cleaner, water temp 85, located in SW FL.
For the first two hours I run the VS at 3000 RPM to achieve initial morning skimming, and heat pump when needed to get the pool started for the day and then drop down to 1450 for the rest of the day (6 hours). I use the quick clean function when using the Pool vac weekly. I have not set up the third timer for use. My AquaRite w/T9 runs for 8 hours daily at 40%.
My question... As this is my first variable speed pump, I wonder what other VS users consider the optimum settings.
I am also curious as to the approx. GPH the VS might be pumping at these RPM. I have 2" plumbing and about 100 ft of head.
TY Jim
TY Jim
