good morning y'all
been a little struggle with my TA, using dry-acid (left overs from previous owners), but will pick up some MA today, however, todays results:
FC: 6.0
CC: 0.5 (very slight pink, one drop cleared it using the 10ml method)
pH: 7.6
TA: 130
CYA: 40
.. looking back at my logs (available through my profile), any suggestions about lowering that TA just a little more, seeing that my pH rose about 0.2 from yesterday. TA results was a little messed up a few days back, up and down. I think I might have messed something up, but confident this mornings was good.
I was thinking today, Acid Demand test, try and bring pH down to 7.0-7.2 with MA, hopefully dropping the TA a bit more and just let pH naturally increase again. I mentioned on some of my other posts, my strainer basket at the pump has a slight crack under the lid. I first thought it was gasket, but definitely a little crack, when I turn my pump off small amounts of water squirts out that crack, so it pulls a little air, hence very slight bubbles on the return, which I think helps with the pH increase a little. I did order a replacement basket, will fit it when I clean/change my filter, maybe this weekend.
FC: 6.0
pH: 7.6
TA: 130
CYA: 40
