G
Guest
Soidum percarbonate will also kill pink slime, btw.
Once the sodium percarbonte had dropped the biguande level to 0 ppm then add your chorine. Once the chloirine levels are 15 ppm change the sand, and add your cyanuric acid and balance the pool.
If I am not mistaken Leslie's Fresh and Clear is NOT sodium percarbonate but is potassium monopersulfate (MPS, the normal non chlorine shock that is sold everywhere) and will NOT successfully convert a biguanide pool to chlorine. If you cannot find sodium percarbonate locally and you do not want to order it online and you do not mind taking a drive to St. Augustine then PM me. We do stock System Support where I work.
