Suction side questions
tikoh
133
Fayetteville, NY
I have a 20x40ft 1970's era inground pool. I have 1 skimmer and 2 returns. Below the skimmer I have a plugged opening of some sort. I had always assumed that it was an old equalizer line that a previous owner had capped for safety reasons. I'm okay with that, although I do dislike having only one suction source.
A friend of mine just bought a house in our neighborhood with a nearly identical pool. However, his suction below the skimmer is still open. It's not connected to the skimmer as an equalizer, it goes straight back to the equipment pad and meets the skimmer line at a diverter valve. Notes from the previous owner state that they normally leave it open 50/50, but when they use the vac hose to the skimmer, they turn the valve to pull mostly from the skimmer.
Our questions are:
1) Is this safe? He has no kids, but I know for me I'd worry about the possibility of getting trapped by the lower suction, especially if the valve were turned to pull 100% from there.
2) If it's not safe, what would you do? The easiest thing would be just to plug it like mine it, but I don't know if that's the best way either.
Our questions are:
At the very least it should have a cover over the port. Is it a 1.5"threaded port? There are covers that would thread into it: Waterway 640-8240V
If not, this can be installed: SDX Retro Hi-flow Safety Cover
An open suction port should never be active while the pool is in use.​
Waterway 640-8240V can be threaded in to make it safer. Amazon.com
