I just joined the forum and I just had a San Juan fiberglass pool put in (around Feb 2020) its a San Juan model has about 3000 gallons give or take
It's only 3 1/2 ft deep and 14 ft by 8ft
I live in St Augustine Fl
I am not wits ends yet but I am getting there!
I can't get my US pool supply suction side pool cleaner to work I pretty much done everything the instruction say (followed the pictures!)
It works but it keeps getting stuck in the corner where it meets the stairs theres return jet I adjusted (and adjusted)
All I can do is clean the filter again and see if that's the problem
The flow seems good on the suction line to the skimmer and it doesn't have any leaks
I have a 3/4 Pentair pump so it should not be a problem it supposed to run on a 1/3 hp pump it says
I would like to know if I missed something
Any suggestions you might have would be great!
