Suction Side Leak, I suspect from this union
OP
OP
funandsun
funandsun
764
Bloomington Indiana
#42
If you tightened up the union, that might have cracked it.
Makes sense
I am innocent. I didn't touch anything, that is why I was surprised. Looks like it is falling apart from the inside.
I assume the water drip I am seeing is from the water coming from the main drain that is still open and leaking out pump side of that union.
Not sure that is correct. I went out and wrapped both unions in plastic wrap until I can get the repair guy over to install new valve(s).
Thanks
OP
OP
funandsun
funandsun
764
Bloomington Indiana
#43
An update to this thread for everyone who was kind enough to help out.
We had a new equipment area built, had the pump and filter relocated and added new Pentair valves and a flowvis flow meter to the set up, the extra area gives us room to grow into a heater and SWCG if we decide to go that direction in the future.
We will be filling in more rock under the deck to level that area out a bit more and give it a more finished look.
This Chapter is closed.
#44
That looks great! How is everything wintering?
