Two pronged question here... I've followed all the usual steps to try and locate a suction side leak. No luck.
30 year old pool, 1 skimmer line to Hayward superpump to sand filter. I've had air bubbles on and off for years. Could never find a fix, so just ignored it.
Recently my heater started shutting off (low flow), because the pump is cavitating and never really getting a good flow going.
Exasperated, I called a pool company. He tried to find the leak and couldn't either. So then he suggested a stop gap fix of putting small eyes on the return jets. I have 2 return jets, and he put maybe 1/2 inch jets on (I had much larger one before). This made my filter pressure jump from 10psi to 19psi. The pump basket didn't fill right up, but did stop cavitating. The heater came on. And only water is coming from the jets (no more bubbles in the pool).
Is this a terrible idea? I under stand why the back pressure from restricting the jets would get pressure up in the heater and make it run. But I don't understand the physics behind why the back pressure he created stops air bubbles in the pool.
Any idea on what is going on? Is the back pressure going to damage my equipment or cause problems as stop gap fix? I assume the efficiency of the filtration process is not great. Could I damage the heater?
In the meantime I'll keep trying to find the air leak. But I've tried all the usual steps.... Frustrated.
Thanks!
Thanks!
