- Nov 12, 2017
- 11,985
- Plaster
- Pentair Intellichlor IC-40
That is odd. Try leaving different kinds of treats in the shallow end until you find which it likes the best.
OK, just kidding. A few things come to mind to try, if you haven't already.
- The owner manual has specific instructions about how to set the length of the hose. You don't necessarily use all that came with it.
- Try fooling around with the position of the float, to see if that makes a difference.
- The long-shot idea is to open the Rebel and see if you can detect anything wrong with, or stuck in, the gears.
- You are using a leader hose, right? Is it the original? They wear out. Mine developed cracks that affected the suction. It's possible that as the main hose stretches, and stresses the leader hose, it might start drawing water through a tiny crack, which would affect the Rebel's ability to climb out of the deep end. That could be true of the main hose, too, come to think of it. Inspect all the hoses for leaks. And/or try swapping hose sections around. If you end up taking a section out when adjusting the length, try swapping the extra section in and out to see if you can determine which section has the leak (if there is one). You get the idea.
- Or if you aren't using a leader hose, start there.
- Buy and use the flow gauge to confirm you have the correct flow.
