- Jun 24, 2021
- 16,618
- Vinyl
- CircuPool RJ-60 Plus
James, you are a genius. I have a REEEAAALLY slow suction side leak, tried shaving cream, nada, rebuilt 3 unions and 2 valves, TWICE and I can't find it to save my soul. Just bought the parts to build a pressurization rig with thru-hole plug. Was going to use it to pressurize the inbound from the unions to the the pump union since it is removable.Try pushing water into the pump from a skimmer. That way the suction is under pressure and a leak will be obvious.
Rig up a garden hose into the skimmer hole with adaptors and push water through the system.
Make sure that the water can flow through the system because city water pressure can be too much for the equipment if the water is blocked
Or, just pressurize the system to about 10 psi to see if the leak becomes obvious.
Couldn't figure out how I was going to do the lines to the pool. I'm sure I would have figured it out, but you saved me the trouble. Thanks!
