- Oct 25, 2015
- 5,828
- Plaster
- CircuPool RJ-60 Plus
RF,
Looking at your photo closely generates a few more questions and suggestions:
- The pump suction line has a 90 and then a manifold of 3 suction sources. I would assume these are spa drain, pool drain, and skimmer. Close these one-at-a-time and see if the bubbles are reduced. Do not accidentally close them all at the same time as this will cavitate the pump. This could help isolate the leak to something above ground.
- Below the suction pipe there is another pipe that comes out of the ground then a valve in the closed position then it is open to air. What is this pipe for?
