Looking for members here to check my logic.
Had a water leak that I think I’ve narrowed down to the suction line. When skimmers are plugged, the pool holds water just fine. When the skimmers are unplugged, water level goes down and skimmer eventually drains dry. Skimmer valve at the equipment (below water level) is closed, so the leak is somewhere between equipment and skimmers. Main drain is plugged.
Can I rule out return line leak and structural leak then and focus on finding where the leak is in the suction line? Problem is everything is under concrete… it’ll be expensive
