Greetings,
I have a 28K gallon inground vinyl liner pool. Since I filled the pool for the first time last summer, I have not been able to produce enough chlorine to keep up. The salt system is an Excel 60K gallon rated system. (I've been using CalHypo to maintain sanitizer level)
I am confident the problem is not high chlorine demand due to algae, etc. Using a Taylor FAS-DPD titration test with 25ml/2 PPM per drop, my overnight loss was .2 PPM. Current readings at end of day today are:
pH 7.5
FC 3.8
CC .4
TA 80
CYA 65
Salt 3700
Water Temp 74°F
I am running the chlorine generator at 100% for 12 hours per day. The voltage supplied to and the current drawn by the cell indicate normal operation at approx 25 volts and 5.3 amps. Just to be sure, I measured the voltage and current with my own meter and the readings match what the cell controller is telling me. I'm quite confient that the electrical conditions at the cell are normal.
Could a faulty cell still draw normal current but produce insufficient chlorine?
I'm very stumped by this.
Thank you.
pH 7.5
FC 3.8
CC .4
TA 80
CYA 65
Salt 3700
Water Temp 74°F
Thank you.
