Greetings TFP Community.
I've been lurking a couple of years and benefited greatly from your advice. Bought a house with an older pool 4 years ago. Water is clean/clear, but gunite pool is showing its age with plaster discolorations and some surface chips. I've completely redone the equipment with a new Easytouch Load Center, the old one was a sparky rat's nest.
Fired my pool guy two years in after he let it go green while we were on vacation one summer (*twice*). TFP method has kept my water sparkly. He used tons of trichlor tabs and my CYA was through the roof (near 180). One year and a 50% drain and refill later, my CYA is now very low (around 20-30, can't quite get the dot to disappear with the Taylor kit).
On to my problem:
I feel like I use way too much chlorine/bleach compared to the stories here in the forum. My pool needs at least a gallon of 10% every other day during the summer heat to keep it between 4 and 8. Sometimes every day. I've been using a Taylor K-2006 kit to track my chemistry. My TA has always been off the charts, and correspondingly pH (pegged at max). This summer I decided to get serious and see if I could move the needle.
20 gallons of Home Depot muriatic and 10 weeks of aeration have brought by TA down from the high 300s to 130. Two gallons of muriatic at a time will lower the pH to 7.2/7.3, but it's right back to 8.0+ after a day of aeration.
I only have semi-hard water from the city's municipal supply to fill. I'm also wondering if last summers' 3-4 shock exercises with cal-hypo left too much calcium, but not sure what that does to my chemistry.
Questions:
Should I keep going lower with my TA? will it help with pH?
Is my CYA too low for my environment?
Can high calcium be caused by multiple cal-hypo shocks over time?
What chemistry symptoms can occur with high calcium (other than scaling)?
Will lower pH help use less chlorine?
Is there something in my aging pool surface causing the high pH?
I would appreciate your help/guesses to any of these.
On to my problem:
Questions:
