FC 12
CC <0.5
TA 90
CYA ~30 (haven't measured since adding CYA last weekend for a target of 40)
The pool was green when opened. I started a SLAM for a few days without vacuuming or brushing because I could not see the bottom of the pool. Eventually after a few days, the green disappeared, but the pool was very cloudy. I continued to SLAM without vacuuming because I couldn't see the bottom but the water was "clean" (Additionally I didn't have a vacuum attachment). After getting the attachment I decided to vacuum even though I couldn't see the bottom of the pool and what happened next was surprising to me (although it should not have been when I think about it). All this green came pouring out of the return. Voila! I still had algae, therefore, the pool could not clear.
Since then I have been SLAMing my pool for 2 weeks - vacuuming and brushing everyday. My OCLT this morning was 0. I STILL cannot see the bottom of my pool. It is cloudy enough that I cannot make out the details on the 3rd step, although I can see the outline of the fourth (bottom) step. Every day before I vacuum I notice just a little bit of "dust" on the top step.
The sand in the filter is only 2 years old. I do run the filter 24/7 for the majority of the season. I did a deep cleaning of the filter before opening the pool this year. I have already done two back washes. After my last BW (last weekend) my filter pressure was 15 psi. It is now at 16. I would normally wait until it gets to 18 to do another BW.
The water fountain has been under the surface of the water to circulate the water. I just removed it today to let be "stock" to see if the circulation is an issue (not sure how it could be)
It it possible that the cloudiness is fine particulate that the filter just cannot contain? Is DE my solution?
CC <0.5
TA 90
